help connect adsl modem with mikrotik routeros
hello,
i have a lan with 40 computers.
from the ISP we got an ADSL modem working with static Ip.
so i have to give users ip’s to connect to internet (not automaticly).
the problem i have is that i cant manage bandwitdth (limit)or disconnect users.
now i want to use mikrotik routerOs to manage everything i want.
I install RouterOs v2.9.27 on a machine with 2 NIC.
but i need help to install this whole thing.
internet-mikrotik-lan users.
Lan ip = 192.168.1.2 - 192.168.1.254
gateway = 192.168.1.1
dns prim=200.1.157.11
dns sec=200.1.156.11
can anyone help me config the system to make it work
regards,
Berto
Hi Berto,
you have to use a Hotspot in the LAN with costumers. There you can put different bandwith limit to each user or you can “close” the hotspot to the “bad” users.
Regards,
ok ty,
but pls tell me how to do it.
configuration ect.
regards,
berto
Hmm.. question, why are you installing v.2.9.27?
Sorry, but sounds suspicious to me..
the version is not the issue right now,
my question is the setup to make my
adsl and mikrotik work
regards
I think it very well is, since 2.9.27 is the latest pirated version available..
Andrea,
did you make the training this MUM in CZ? I think we stay in the same class..
Surparbo,
It’s too easy to make a hotspot. You have to read the WiKi, but with this cracked version you’ll have a lot of problems. Try to buy a cheap L4 license of 3.0 ; ) I think you can try it in demo 24h version.
Hi Martin,
I was on the train-the-trainers course.
Suparbo, you can even get a free license with some limitations, which from your descriptions you are not getting to. But I agree with Martin, easier to just buy a L4 license, it doesn’t cost much
then
then
Busted!
Either use a legit version or stop bugging us.
you guys are right …not known this is a pirate version.
i bought it from a local shop telling me this is a good software for bandwidth managing .
well i think its a good software indeed, but this crack version sucks.
Anyway my apologize and the good news is that i order two RB433AH Routerboards.
Best regards,
Berto
another convert.. you have been healed my son :slight_smile:
Well good for you for coming clean. Not many do though so apologies for the heavy hand in my earlier reply.
