The connection it’s established but i canno’t ping o do other to the Internal IP of the other site
which reads as if IPsec tunnel is working but no data is passed on it.
So, is it the LAN-to-LAN flowing? Can you reach remote hosts through the VPN? Please check in IPsec > Installed SAs and see if “Current Bytes” increments.
If it’s a matter of slowness, check the latency outside of the tunnel (from public IP to public IP) and compare it with the latency inside the VPN, maybe it’s a matter of connectivity.
You can also check the CPU load of the routers on both sides.
Hi yes the current bytes it’s increment’s but it’s very slowly…i think there is a kind of implementation that i didn’t do…because yesterday…after all it was completely functionally
