help crossing subnets/vlans
When I’ve setup different subnets and vlans I am having trouble talking across them. For example I have several vlans on different /24 networks and although the router can ping them and I can access them with my VPN, if I’m plugged into and getting an IP from one of the subnets I can’t reach IP’s outside of that /24
I’m using 172.16.0.0/12
My base vlan is 172.16.5.0/24
I have some other vlans in 172.17.5.0/24, 172.25.10.0/24, etc
Can I make a rule that lets me access everything in 172.16.0.0/12 as long as I’m getting an address anywhere in that range?
Thanks!
Please post your config
/export hide-sensitive file=myconfig
Thanks for checking it out!
jan/31/2019 21:50:04 by RouterOS 6.43.8
software id = 9L9C-QQ19
model = RB4011iGS+
serial number =
add admin-mac=B8:69:F4:BA:85:DE auto-mac=no comment=defconf name=bridge
set [ find default-name=sfp-sfpplus1 ] name=sfp-sfpplus1-WAN speed=1Gbps
/interface vlan
add interface=bridge name=vlan17-servers vlan-id=17
add interface=bridge name=vlan101-T1Radios vlan-id=101
add interface=bridge name=vlan1001-T1Subs vlan-id=1001
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=172.16.5.100-172.16.5.200
add name=vpn ranges=172.16.0.100-172.16.0.200
add name=dhcp_pool2 ranges=172.17.5.100-172.17.5.254
add name=dhcp_pool3 ranges=172.25.10.200-172.25.10.250
add name=dhcp_pool4 ranges=10.10.10.201-10.10.10.250
add name=dhcp_pool5 ranges=172.25.10.200-172.25.10.250
add name=dhcp_pool6 ranges=10.10.10.200-10.10.10.250
add address-pool=dhcp disabled=no interface=bridge name=defconf
add address-pool=dhcp_pool2 disabled=no interface=vlan17-servers name=dhcp1
add address-pool=dhcp_pool5 disabled=no interface=vlan101-T1Radios name=dhcp2
add address-pool=dhcp_pool6 disabled=no interface=vlan1001-T1Subs name=dhcp3
/ppp profile
set *FFFFFFFE local-address=172.16.0.1 remote-address=vpn
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf disabled=yes interface=sfp-sfpplus1-WAN
add bridge=bridge interface=ether1
/interface l2tp-server server
set enabled=yes use-ipsec=yes
add interface=sfp-sfpplus1-WAN list=WAN
/interface pptp-server server
set enabled=yes
/interface sstp-server server
set default-profile=default-encryption enabled=yes
add address=172.16.5.1/24 comment=defconf interface=ether1 network=172.16.5.0
add address=70.xxx.xxx.106/29 interface=sfp-sfpplus1-WAN network=
70.xxx.xxx.104
add address=172.17.5.1/24 interface=vlan17-servers network=172.17.5.0
add address=172.25.10.1/24 interface=vlan101-T1Radios network=172.25.10.0
add address=10.10.10.1/24 interface=vlan1001-T1Subs network=10.10.10.0
add address=70.xxx.xxx.107/29 interface=sfp-sfpplus1-WAN network=
70.xxx.xxx.104
add address=70.xxx.xxx.108/29 interface=sfp-sfpplus1-WAN network=
70.xxx.xxx.104
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid interface=sfp-sfpplus1-WAN
add address=10.10.10.0/24 gateway=10.10.10.1
add address=172.16.5.0/24 comment=defconf gateway=172.16.5.1 netmask=24
add address=172.17.5.0/24 gateway=172.17.5.1
add address=172.25.10.0/24 gateway=172.25.10.1
set allow-remote-requests=yes servers=1.1.1.1
/ip dns static
add address=172.16.5.1 name=router.lan
add action=accept chain=input comment=
"defconf: accept established,related,untracked" connection-state=
add action=accept chain=input comment="allow any from inside/vpn"
src-address=172.16.0.0/12
add action=accept chain=input src-address=172.25.10.0/24
add action=accept chain=input comment="allow IPsec NAT" dst-port=4500
protocol=udp
add action=accept chain=input comment="allow IKE" dst-port=500 protocol=udp
add action=accept chain=input comment="allow l2tp" dst-port=1701 protocol=udp
add action=accept chain=input comment="allow pptp" dst-port=1723 protocol=tcp
add action=accept chain=input comment="allow sstp" dst-port=443 protocol=tcp
add action=drop chain=input comment="defconf: drop invalid" connection-state=
invalid
add action=drop chain=input comment="defconf: drop all not coming from LAN"
in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept in ipsec policy"
ipsec-policy=in,ipsec
add action=accept chain=forward comment="defconf: accept out ipsec policy"
ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment="defconf: fasttrack"
"defconf: accept established,related, untracked" connection-state=
add action=drop chain=forward comment="defconf: drop invalid"
connection-state=invalid
"defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat
add action=dst-nat chain=dstnat dst-address=70.xxx.xxx.107 to-addresses=
172.17.5.253
add action=src-nat chain=srcnat dst-address=70.xxx.xxx.107 src-address=
172.17.5.253 to-addresses=70.xxx.xxx.107
add action=masquerade chain=srcnat comment="defconf: masquerade"
add action=masquerade chain=srcnat comment="masq. vpn traffic" src-address=
172.16.0.0/12
add action=masquerade chain=srcnat src-address=172.25.10.0/24
add action=masquerade chain=srcnat disabled=yes src-address=172.17.5.0/24
add action=masquerade chain=srcnat src-address=10.10.10.0/24
add distance=1 gateway=70.xxx.xxx.105
/ppp secret
add name=vpn
/system clock
set time-zone-name=America/Phoenix
/system identity
set name=RW_Core
/tool mac-server
/tool mac-server mac-winbox
You need to make these src-nat rules more selective (e.g. use out-interface as well):
add action=masquerade chain=srcnat comment="masq. vpn traffic" src-address=172.16.0.0/12
Probably you really only use the first one (with addition of out-interface being name of VPN interface), right now it overlaps the next two. The other 3 are (most probably) adequately covered by the preceeding
which src-nats everything going out to WAN. I don’t think you need src-nat for inter-VLAN connections.
You need to re-think the VPN masquerade rule as it doesn’t cover VLAN 10.10.10.0/24 … currently the last rule covers that but if you’ll rework NAT rules, take care of it as well.
Thank you!
What is the purpose of identical or near identical pools??
I note that 2,5,6 pools are the ones actually noted in the applicable server entry.
This should not be on the bridge port rules but I see its disabled.
The Interface for address of LAN should be interface=bridge
Plus Duplicate entry in address at the end???
70.xxx.xxx.104
70.xxx.xxx.104
70.xxx.xxx.104
You can get rid of the legacy/default dns static rule
/ip dns static
Besides mKX on only needing one properly formatted masquerade rule…
add action=dst-nat chain=dstnat in-interface=wan to-addresses=serverIP
You need also protocol and destination port
