Help customers routers limitations and profiles
dear all,
is there a way to create a customer with the following rights:
can create users of his own
can use parent router < no right to modify parent router
can use parent limitation < no right to modify parent limitation
can use parent profile < no right to modify parent profile
also if possible can see parent users but no right to modify any parent user
thank you
