Hi can some one give a little advice i am allowing 50 tcp connection per ip but is it possible to limit just facebook to 20 tcp connections.
or is it possible to limit just facebook games and not facebook or http browsing.
If you using PCQ tree you have to change the 50/2000 which is default to your need.
