IS0FFD
April 28, 2018, 8:32am
1
Hi all!
I’ve a CRS125 with this firewall rules
17 ;;; Port Scanner Detect
chain=input action=add-src-to-address-list protocol=tcp psd=21,3s,3,1 address-list=Port_Scanner address-list-timeout=1w
18 ;;; Drop to port scan list
chain=input action=drop src-address-list=Port_Scanner
In my lan i’ve a RB750gr3 with Dude, but is continually inserted in the “Port_Scanner” list
How can I solve?
Extract Hex IP from list or deactivate the rule?
IS0FFD
April 28, 2018, 9:46am
3
I would like it if possible to make a white list with the addresses known to be excluded from the rule.
sorry but I’m trying to learn!
Try something like this:
chain=input action=accept protocol=tcp psd=21,3s,3,1 src-address=“IP of HEx”
or with a white list:
chain=input action=drop src-address-list=!White_List
chain=input action=accept protocol=tcp psd=21,3s,3,1 address-list=White_List
“=!” - mean not what you point on.
IS0FFD
April 28, 2018, 10:43am
5
chain=input action=accept protocol=tcp psd=21,3s,3,1 src-address="IP of HEx"
not work…
Sorry, but you assigned in src-address IP address of your Hex router or just words I wrote?
And I’m sorry for incorrect sequence:
chain=input action=accept protocol=tcp psd=21,3s,3,1 src-address=“IP of your Hex”
Not…I mean you have to use not (!) so you need only one line.
add chain= input action=add-src-to-address-list protocol=tcp psd=21,3s,3,1 src-address=!"IP of your Hex" address-list=Port_Scanner address-list-timeout=1w
I will suggest you an other thing, remove firewall roles from switch, because switches get more CPU usage form firewall roles!
anav
April 28, 2018, 3:23pm
10
Hi there, I do something very similar…
(I have two WAN IPs, otherwise I would have probably used in-interface WAN)
IP Filter
{Port Scans TCP make list}
chain=input action=add-src-to-address-list protocol=tcp dst ports=23, 53,123,445,8291 in-interface list-WAN address-list=port_scans_tcp-timeout=2d
{Port Scans UDP make list}
chain=input action=add-src-to-address-list protocol=tcp dst ports=23, 53,123,445,8291 in-interface list-WAN address-list=port_scans_udp-timeout=2d
Then I use RAW fule (not filters) and PRE-ROUTING to kill the list entries before they enter the router at all (no tracking etc…)
IP RAW
{Drop Scans TCP}
chain=prerouting action=drop src-address-list=port_scans_tcp
{Drop Scans UDP}
chain=prerouting action=drop src-address-list=port_scans_udp
