Help for a ATL LTE conection
Hi everyone. I bought a MikroTik ATL series (I living in a rural area), together with a hap AC2 lite (but here if I have any problems I’ll tell you later).
The routerboard after a few attempts on the configuration (primarily of the APN), seems to work correctly on the BTS “windtre” (italian operator) and the LTE interface is active so much so that I was able to update the operating system and the firmware, etc. The problem is that by connecting directly to the Ethernet cable that goes out to the antenna, I’ve tried 1000 ways but I can’t navigate. Later I will then try to connect it to the hap simply because it distributes the Wi-Fi signal in the house.
Thanks for whatever you can help me.
Happy Easter.
Davide.
