Help for a routing configuration of RBcAP2nD
Hello everybody!
I need a little help configuring a MikroTik RBcAP2nD ad a wireless router.
The LAN cable is connected to an ADSL router (192.168.1.1)
The wireless is used for guest web navigation (192.168.10.1 and dhcp from 192.168.10.100 to 192.168.10.150).
Everything is OK, but I need that the Wifi users can ONLY use web and DO NOT VIEW / PING / USE the wired network (192.168.1.1-192.168.1.254).
How can i set this?
Please, I’m a newbie… step to step… thanks :slight_smile:
Have a nice day!
Regards!
Claudio
Hi, you can check by removing the static route or proxy-arp disabled
