Help for adding routeros devices to Zabbix
Hello
i want to add my mikrotik devices to zabbix with snmpv3, but i don’t know how and i cant find a good tutorial for that, can someone help me ?
It’s been a while since I played with Zabbix but have you enabled SNMP on your Mikrotik with proper trap version ?
Winbox / IP / SNMP
And most likely (depending on your config) you should also allow in your firewall input for port 161/UDP (to be safe: allow only src IP address from Zabbix server).
i cant add any device with snmpv3, only snmpv2
Perhaps some ideas from here?
https://blog.zabbix.com/monitoring-network-hardware-with-snmpv3-in-zabbix/10093/#
thank you, it can help me
