Hi all,
I’ve my first mikrotik router via my company.
I need to configure it .
the firmware version is 6.2 (model 24 ports without wifi)
currently, there is already 1 mikrotik router on Production in the company (firmware 6.5 (model 24 ports with wifi) )
I need to setup the new router with the same config that the currently used.
3 vlans - DONE
2 FAI - DONE
problem:
setup vlan 1 and 2 for use in priority FAI 1
setup vlan 3 for use in priority FAI 2.
I don’t know how to do it.
Thanks for answer.
Regards
