help for FTP server
**hello every buddy
that first topic to me in the forum
i want to make ftp sever on mikrotik to transfire files
i cant active the ftp on mikrotik
plz if can some one help me fast**
Why is this in the User Manager forum? Are you running User Manager?
To enable the FTP service:
/ip service enable ftp
Also make sure you have no firewall filter rules blocking FTP in the input/output chain.
FTP is enabled by default.
hummm
i make it before
hum i have Q?
how i use or open the ftp server
i used the browser and flash XP to open
but the habend
This address uses a network port which is normally used for purposes other than Web browsing. Firefox has canceled the request for your protection.
So try using a proper FTP client.
Thanks for the follow-up and quick reply
But I want a full explanation to open the ftp
I was probably the work of the errors, because even I can not open the ftp :open_mouth:
