Help for SXT 5HPnD5 and SXT Lite5
Hi i need some one help, to link up two point with internet connection in 2.5km before i choosing the hardware i need some expert info. if i using SXT 5HPnD5 as AP and the other site using SXT Lite5 as client.
AS i know the Mikrotik OS control about the level? for level4 only can use as AP and
level3 cannot as AP only client. please i need some help before i purchase the product.
thank you.
You can build a bridge with 2 SXT Lite5
Gesendet von meinem GT-N7000 mit Tapatalk-4
Thanks fo reply. As SXT Lite5 can get stability for 2.5km i wonder the 16dbi internal antenna can do the best performance?
Of course it would be better to have a higher gain antenna.
But it would be bigger and more expensive. For it’s size the
SXT-Antenna is quite good. The Sextant did not perform better
in our tests. You can combine RB912UAG-5HPnD-OUT with a
parabolic dish and you will get better results for sure.
