hi,
i’m trying to setup a vpn on a sxt lte mikrotik. I use the built in vpn setup on webconfig.
whe i try to connect by windows with pptp it works but if i try with android is non possibile.
Andorid ask for lpt2 ip sec or openvpn. Are there any solution or setup to apply for connect from android to the vpn
Yes the wiki has extensive documentation on the topic. Using L2TP/IPSEC for remote access or “road warrior” as the wiki calls it is nice because all major OS versions support it built-in right now. Technically I prefer IKEv2 but Android doesn’t have native support for it yet. All other platforms do.
Hi, I tried but I am not able to setup correctly.
Maybe I do not understand what I have to do.
My scenario is a network that by lte builtin modem is connected to internet and on webconfig page I can see ip but it can change when reconnect. Ip is 100.x.x.x and is NAt so I can not access by portforwaring or ddns.
I have the sxt routerboard lan as default Io as 192.168.88.x and a subnet with 192.168.1.x
And I would like to access to a hub server with 192.168.1.200 ip from. Android outside VPN client.
Can someone help me to setup VPN with l2tp IPsec or ikev2?
