I've been attempting to forward all incoming traffic from the WAN (ether 1) port 502 to 502 server at 192.168.17.60 port 502. I believe I followed the instructions online using WinBox. After it failed, did add the WAN's ip address in the dst. addr of the dst-nat rule.
Questions: DId I get this right? Is there some other rule in the way? Help? Please?
Thanks,
Mark
# nov/06/2025 12:55:11 by RouterOS 6.49.19
# software id = RTMY-4X4C
# model = RB951Ui-2nD
# serial number = C8360C25BC0F
add admin-mac=48:8F:5A:7D:3E:C1 auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX disabled=no distance=indoors frequency=auto \
installation=indoor mode=ap-bridge ssid="MLB Electronics" station-roaming=enabled wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik \
add name=dhcp ranges=192.168.17.100-192.168.17.150
add address-pool=dhcp disabled=no interface=bridge name=defconf
/user group
set full policy=\
local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,web,sniff,sensitive,api,romon,dude,tikapp
add address=192.168.17.252/24 comment=defconf interface=bridge network=192.168.17.0
add address=192.168.0.75/24 interface=ether1 network=192.168.0.0
/ip dhcp-client
add address=192.168.17.0/24 comment=defconf gateway=192.168.17.252 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.17.252 comment=defconf name=router.lan
add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=\
add action=drop chain=input comment="defconf: drop invalid" connection-state=invalid disabled=yes
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=input comment="defconf: drop all not coming from LAN" disabled=yes in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related, untracked" connection-state=\
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
add action=masquerade chain=srcnat comment="defconf: masquerade" disabled=yes ipsec-policy=out,none out-interface-list=\
WAN
add action=dst-nat chain=dstnat dst-address=192.168.0.75 dst-port=502 in-interface-list=WAN protocol=tcp src-port="" \
to-addresses=192.168.17.60 to-ports=502
add distance=1 gateway=192.168.0.1
/system clock
set time-zone-name=America/Chicago
/tool mac-server
/tool mac-server mac-winbox
