sorry if my english bad (use google translate);
I have two router for pppoe server, running fine with normal cpu load,
Router A ccr2116 v7 = firewall,nat,mangle
Router B rb1100ahx4 v6 = pppoe server,dhcp, disable NAT, disable connection tracking
the question is, how I create hotspot from router A but dhcp server from router B? how to do that?
I still need to disable nat+conntrack in router B to reduce cpu load, since router B disable conntrack then I can’t make hotspot work properly because hotspot rule (create automatic when create hotspot) need conntrack to work with login page(autenticated user).
something like this
Router A ccr2116 v7 = firewall,nat,mangle,hotspot rule
Router B rb1100ahx4 v6 = pppoe server,dhcp server for pppoe and hotspot different subnet, disable NAT, disable connection tracking
thank for your help
