As per the manual I want to redirect login attempts to our external authentication server. So I set it up as manula below which works fine, goes to server and all that:
Modify login page of the HotSpot servlet to redirect to the external authentication server. The
external server should modify RADIUS database as needed
Here is an example of such a login page to put on the HotSpot router (it is redirecting to
https://auth.example.com/login.php> , replace with the actual address of an external
authentication server):
That is fine, however I then need to point our server back to the mikrotik so it will do the radius login.
So as per the manual:
The external server can log in a HotSpot client by redirecting it back to the original HotSpot
Hotspot login page
servlet login page, specifying the correct username and password
Here is an example of such a page (it is redirecting to > https://hotspot.example.com/login> ,
replace with the actual address of a HotSpot router; also, it is displaying > http://www.mikrotik.com
after successful login, replace with what needed):
We dont have SSL enabled, so we replace https with http, but:
http://hotspot.example.com/login
just gives an error as the page cant be found. When you access that domain, it is the management interface, which is not what you want right. So I thought it was on a different port, couldnt work that out?
Am I missing something?
