HELP! How to find the routeros backup files?
My RouterOS 5.8 boot error. HELP! How to find the routeros backup files? THANKS.
Hello
are you using X86 architecture ?
if you use that reinstall your routeros with ISO file and for question “keep old configuration?” type “yes”
if you use routerboard install routeros with netinstall and select keep old configuration
Good Luck
