mwpmo
March 27, 2007, 3:23am
1
I got a WAN link (WAN1) with a speed 6M/512k
I wish to set all the http traffic with higher priority than others.
(both in and out cause I got a web server inside my LAN)
Is the following code correct?
/ ip firewall mangle
add chain=prerouting protocol=tcp dst-port=80 action=mark-packet \
new-packet-mark=high passthrough=yes comment="" disabled=no
add chain=prerouting protocol=tcp packet-mark=!high action=mark-packet \
new-packet-mark=normal passthrough=yes comment="" disabled=no
/ queue simple
add name="Main" dst-address=0.0.0.0/0 interface=WAN1 parent=none \
direction=both priority=8 queue=default-small/default-small limit-at=0/0 \
max-limit=0/0 total-queue=default-small disabled=no
add name="High" dst-address=0.0.0.0/0 interface=WAN1 parent=Main \
packet-marks=high direction=both priority=1 \
queue=default-small/default-small limit-at=0/0 max-limit=0/0 \
add name="Normal" dst-address=0.0.0.0/0 interface=WAN1 parent=Main \
packet-marks=normal direction=both priority=8 \
queue=default-small/default-small limit-at=6000000/512000 \
max-limit=6000000/512000 total-queue=default-small disabled=no
janisk
March 28, 2007, 8:13am
3
to prioritize your traffic in your first rule change passthrough=yes to no and then mark all the rest of traffic
in queues, better use queue tree.
add ine queue that holds ALL THE TRAFFIC and thena add child queues for high priority (in your case HTTP) traffic and then queue for the rest,
and set correct priorities.
here is the link to the manual:
http://www.mikrotik.com/testdocs/ros/2.9/root/queue.php
mwpmo
March 28, 2007, 8:57am
4
Thanks a lot!
Some more questions.
Should I mangle the packets in “pre-routing” chain or “forward” chain
Should I user WAN1 as the parent field in the queue tree (WAN1 is the interface to internet)
The code now (“local-address” is the address list for all workstation & server inside)
add chain=prerouting protocol=tcp dst-port=80 src-address-list=local-addr \
action=mark-packet new-packet-mark=high passthrough=yes comment="" \
disabled=no
/ queue tree
add name="High" parent="WAN1 Queue" packet-mark=high limit-at=0 \
queue=ethernet-default priority=1 max-limit=0 burst-limit=0 \
burst-threshold=0 burst-time=0s disabled=no
add name="Normal" parent="WAN1 Queue" packet-mark=normal limit-at=0 \
queue=ethernet-default priority=8 max-limit=0 burst-limit=0 \
add name="WAN1 Queue" parent=WAN1 packet-mark="" limit-at=0 \
Is is correct?
In winbox, now I found that the Rate shown for the queue “WAN1 Queue” (sum of “High” queue and “Normal” queue) is much smaller than the Rate shown in the interface windows.
Is that normal?
