[HELP] I need OpenVPN Client only on Specific virtual Wireless LAN and physical LAN ports
Hi Everyone!
I have a RB2011UiAS-2HnD.
It’s connected to ineternet on eth1 port.
I could successfully connect it to another OpenVPN server.
But the problem is that it affects all physical ports and WLAN and virtual WLANs traffics and the whole traffic from this ports goes through OpenVPN.
1- I want to have OpenVPN traffic only on the Virtual WLAN, Eth3 and Eth4
2- The rest of ports should be connected to internet directly
Could you help me do it from the scratch (if it’s needed I can reset the router’s configuration) using Winbox or Terminal?
