Help in Command for return Information of Wireless
Hi Peoples…
I developed a small software for the technical lead up to the client, and verify some information such as: tx / rx CCK, Ack timeout, signal to noise that client …
type:
the technician put the client’s IP, the program connects the radio, and radio would return this information in the program (the client’s home).
I need only a command line that returns this information to a customer from a query by IP.
Excuse my Bad English …
you have developed such program, or you want to?
if you want to, you can probably use the API to do it:
http://wiki.mikrotik.com/wiki/API
With the php API you can also to that
 $API->write('/interface/wireless/registration-table/print',false);
 $API->write('=stats=');
I use it to output All info of eatch registered client for our support team !
I put info on the wiki
http://wiki.mikrotik.com/wiki/API_PHP_class
