Help Installing Certificate
I’m trying to setup sstp and I know I need a ssl certificate installed. The problem I’m running into is that when I’m importing the file exported from my windows IIS server or the one I download from GoDaddy it’s in a .crt format and I’m able to import it but when I try to decrypt it, my Mikrotik says there were 0 keys decrypted…
Can anybody give me some help.
Ok, I figured out how to get the certificate installed.
