Help, is anybody see such problem: 2 of 3 wireless cards CM9 work as bridge/ap-bridge, the 3nd - only as a station. Celeron-D/2.6GHz;256RAM;ROSv2.9.6
Have you tried swapping the cards around, to identify if the problem is related to a specific card, or if it perhaps is a config error or the like?
Best regards,
Christian
Yes, I change the place of the cards onto PCI slots, these all cards are changed, I even try with a CM6, but the same result.
When I start using the router there was 3 cards, but the 3rd - disabled. At the moment when I enable #3 - there wake up a problem. In a scan other cards can’t “see” this card. And she “saw” others. I put the card in a station mode - she works fine. I suppose there is no limit of used cards number… any suggestions?
kind regards,
chvdr
