[Help] Linking Mik Boards To A Domain Name And Subdomains
Greetings
i need an answer for this Q please
The Q is:
i hv a domain name, and i have 4 mik boards, can i set a domain/subdomain on each mik board so i can access them from anywhere ?
if yes where i can read about this option on how to set nd setup..
am doing this cuz these 4 mik boards are far away from and not connected to my Base connected to other base which i dont have access to it ..
thank you
You have to maintain dns record on your registering dns server to aim subdomain to the public ip addresses of your routers. Nothing to do inside the devices.
If you don’t have static IPs, you can make sure you are using at least ROS v6.14 and use IP Cloud. Each routerboard has a unique DNS name in IP Cloud and you can create CNAME records with your domain name to point to each one of these records. IP Cloud will automatically keep the IP address up to date for you.
