help logging into RB133 by serial port
both my RB133s went offline today, I can’t ping either of them.
I’m trying to access them by the serial port but can’t get any recognizable characters, only symbols.
I put a 751 on and tried using Winbox to search for them, that doesn’t work nor does IP neighbors.
What terminal type do I need to use in Hyper terminal?
bit: 115200
data: 8
parity: none
stop: 1
flow control: none
emulation: VT100J
terminal id: VT100
It’s the time to change such old devices.
I had tried almost every speed but 115k, that was the trick to making it work.
For some reason I had made a note the router would not connect at that speed.
I’m Italian, not English. Sorry for my imperfect grammar.
Your English is better than my Italian.
