HELP ME ABOUT 2.3 GHZ
Hello every body i need help in TP-LINK i want to run 2.3ghz frequency i am using 501g and 601g tplink Access Points .is there any channel in those router boards that i can use 2.3 frequency .if there is any firmware regarding that pls guide me
Regrets, no solution for you. I tried to push TP-LINK 500G/501G/5110G/5210G to run on non-standard channels on 2.3GHz band but with no success. Try UBNT NS 2.4, work great if you set compliance test mode with scan list enabled or korea republic2 selection. Of course, if you are able to do that in your country due to regulatory policies. :confused:
