i want to put rate limit of 1.5 mb,how can write this in mb or kb?
1.5M should work.
If it does not the decimal is the issue. It may only take 1M or 2M. You may need to use K in the thousands instead of the decimal.
thanks dear 1536k act as 1.5 mb.
1.5M should work.
