Hello
I have my Wifi assigned to 192.168.2.36, however, my wifi does not connect to the internet. I also can not ping the wifi router.
Please help me how do I configure the RouterOS to funtion.
Below is my config file:
# 2026-04-18 12:55:55 by RouterOS 7.18.2
# software id = KQD3-DZA4
# model = RB5009UG+S+
add admin-mac=04:F4:1C:30:18:8C auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] name=eth1_WAN
set [ find default-name=ether3 ] name=eth3_WIFI_DECO
set [ find default-name=ether6 ] name=eth6_UNIFI
set [ find default-name=ether7 ] name=eth7_NETGEAR
set [ find default-name=ether8 ] name=eth8_HIKVISION
set [ find default-name=ether2 ] disabled=yes
/interface wireguard
add listen-port=13231 mtu=1420 name=WG
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.1.3-192.168.2.254
add address-pool=dhcp interface=bridge name=defconf
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment=defconf interface=eth3_WIFI_DECO
add bridge=bridge comment=defconf interface=eth6_UNIFI
add bridge=bridge comment=defconf interface=eth7_NETGEAR
add bridge=bridge comment=defconf interface=eth8_HIKVISION
add bridge=bridge comment=defconf interface=sfp-sfpplus1
add comment=defconf interface=eth1_WAN list=WAN
/interface wireguard peers
add allowed-address=192.168.77.3/32 client-address=192.168.77.3/32 \
client-dns=8.8.8.8,8.8.4.4,1.1.1.1 client-endpoint=142.255.3.18 comment=\
Jashgfdhon-iPhone interface=WG name=Jashgdfhon-iPhone private-key=\
"gfdsgfdsgfdsg" public-key=\
"gfdgsfdgfdsg"
add allowed-address=192.168.77.2/32 client-address=192.168.77.2/32 \
Jashgfon-Home-Desktop interface=WG name=Jhgfdhason-Home-Desktop private-key=\
"gfdsgdfsgfdsg" public-key=\
"hgfdjhgfjhgfjhgfj"
add address=192.168.1.1/23 comment=defconf interface=bridge network=\
192.168.0.0
add address=192.168.77.1/24 comment=Wireguard interface=WG network=\
192.168.77.0
/ip arp
add address=192.168.1.74 comment="NVR: Unifi Protect" interface=bridge \
add address=192.168.1.66 comment="SWITCH: MIKROTIK" interface=bridge \
add address=192.168.1.45 comment="Main Server" interface=bridge mac-address=\
add address=192.168.1.233 comment="CAM: Paking Lot 180 View" interface=bridge \
add address=192.168.1.238 comment="CAM: FRONT 180 View" interface=bridge \
add address=192.168.1.236 comment="CAM: Stucco Room" interface=bridge \
add address=192.168.1.235 comment="CAM: Delivery Spot" interface=bridge \
add address=192.168.1.234 comment="CAM: FRONT 189 View Yard" interface=bridge \
add address=192.168.1.17 comment="NVR: Front" interface=bridge mac-address=\
add address=192.168.1.38 comment="NVR: BACK LTS" interface=bridge \
add address=192.168.1.39 comment="NVR: OFFICE LTS" interface=bridge \
add address=192.168.1.52 comment="SWITCH: NETGEAR R7800" interface=bridge \
add address=192.168.1.51 comment="SWITCH: DECO-M5" interface=bridge \
add address=192.168.1.6 comment="SWITCH: DECO-M5" interface=bridge \
add address=192.168.1.3 comment="SWITCH: DECO-X55" interface=bridge \
add address=192.168.1.22 comment="SWITCH: DECO-X55" interface=bridge \
add address=192.168.1.237 comment="CAM: Front Desk Counter Customer Spot" \
interface=bridge
add address=192.168.1.239 comment="CAM: Back Container" interface=bridge \
add address=192.168.1.240 comment="CAM: Back Second Floor" interface=bridge \
add address=192.168.1.108 comment="NVR: Back - Old" interface=bridge \
add address=192.168.1.232 comment="CAM: BACK SHEETROCK 180" interface=bridge \
add address=192.168.1.231 comment="CAM: FRONT DESK" interface=bridge \
add address=192.168.2.36 interface=bridge
add address=192.168.1.101 comment=FRONT-CANON interface=bridge
/ip dhcp-client
add address=192.168.0.0/23 comment=defconf dns-server=192.168.1.1 gateway=\
192.168.1.1 netmask=23
set allow-remote-requests=yes
/ip dns static
add address=192.168.1.1 comment=defconf name=router.lan type=A
established,related,untracked
add action=accept chain=input comment=Wireguard dst-port=13231 protocol=udp
invalid log-prefix=FW_DROP_INPUT
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid log-prefix=FW_DROPPED
add action=dst-nat chain=dstnat comment=SERVER_HTTP dst-port=80 \
in-interface-list=WAN protocol=tcp to-addresses=192.168.1.45 to-ports=80
add action=dst-nat chain=dstnat comment=SERVER_SQL dst-port=9001 \
in-interface-list=WAN protocol=tcp to-addresses=192.168.1.45 to-ports=\
1433
add action=dst-nat chain=dstnat comment=SERVER_RD_TCP disabled=yes dst-port=\
3391 in-interface-list=WAN protocol=tcp to-addresses=192.168.1.45 \
to-ports=3389
add action=dst-nat chain=dstnat comment=SERVER_RD_UDP disabled=yes dst-port=\
3391 in-interface-list=WAN protocol=udp to-addresses=192.168.1.45 \
to-ports=3389
add action=dst-nat chain=dstnat comment=NVR_OFFICE_TCP dst-port=8500 \
in-interface-list=WAN protocol=tcp to-addresses=192.168.1.39 to-ports=\
8000
add action=dst-nat chain=dstnat comment=NVR_BACK_TCP dst-port=8501 \
in-interface-list=WAN protocol=tcp to-addresses=192.168.1.38 to-ports=\
8000
add action=dst-nat chain=dstnat comment=NVR_FRONT_TCP dst-port=8502 \
in-interface-list=WAN protocol=tcp to-addresses=192.168.1.17 to-ports=\
8000
add action=dst-nat chain=dstnat comment=NVR_BACK_OLD_TCP dst-port=8503 \
in-interface-list=WAN log-prefix=NVR_BACK_OLD_TCP protocol=tcp \
to-addresses=192.168.1.108 to-ports=8000
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes port=8080
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
dst-port=33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
add action=fasttrack-connection chain=forward comment="defconf: fasttrack6" \
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=America/New_York
/system identity
set name="MikroTik Router"
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
