Help me I'm Starting mesh network
Hi all :slight_smile:
I run wisp on 5.8 network
And would like to give wifi to my whole town on hotspot but it’s big aria so which device is suitable and on how much distance it being fixed i read one topic about mesh network but my first question is which device is suitable ? & How I configur them? :slight_smile:
have you seen this?
http://forum.mikrotik.com/t/what-difference-is-there-between-tp-link-and-mikrotik-router/82146/1
If not, read it first. Seems that you have the same idea like “acooperator” that choosing one device is enough to solve all requierements…
Hope you will change your opinion.
I don’t think TBS was suggesting using a single AP as acooperator did. Unless of course he wants to create a ‘mesh’ out of a single AP :slight_smile:
Maybe not exactly, but such question looked similar to me. Anyway it is better to build star topology network with some backup rings using ap/client connections than wds/mesh grid from all Ap devices.
