hi allll..
i ask , can i combination 5 pppoe client or more in mikrotik router, any router model must be using
i doing this to get high bandwidth ==> 5 pppoe client = 2Mbit = 250$
2Mbit dedicated band = 1000$
hi allll..
i believe that you want to run 5 pppoe-out connections over 1 DSL line, is that correct?
if so, yes that is possible, just set your dsl router into bridge mode and create 5 pppoe-out connections, with the username and password of each account.
if this is not what you are trying to do then please post a full network diagram and a clearer explanation.
I want to do a similar thing.
I have 2 different adsl connections:
(1) normal unshaped un-throttled account.
(2) shaped uncapped (throttled 512kbps) account
I would like to do the following:
Connection (1): Everthing but torrents
Connection (2): torrents ![]()
I’ve been thinking about using the web proxy function but I wanted some opinions on what to do and maybe a few pointers on the how. I’m very much a noob at this point, using winbox.
