Help me plzz.... :(
Hi All.. I’m so glad that i found this site, hope i can learn many things from seniors in this forum :blush:
Guys, i’ve just setup an ISP with former clients is my internet cafes. I use MT to route my network. Here is the configuration:
Public Network GW------| |—National Network GW
------------------------- Router--------------------------
Proxy Server-----------| |-----------Clients
Proxy Server, Router and Clients is on a network LAN
the BW for public is 512K and national is 5M
So i have 3 interfaces on the router, Public, National (Local), and LAN
I do the following setup:
  • Route all the dst-address to specific GW
  • I use a computer act as a proxy server (running FreeBSD)
  • Every Clients which connect through port 80 will be redirected to the proxy server
  • I use queue tree to limit bandwidth for each routing (to Public and to National Local) as the LAN is looseless BW
  • The proxy server works only for the address list that route through Public GW
My problem :
  • As the proxy server act as mediator for the client and public, the proxy always uses the highest bandwidth (in this case all of the public BW)
  • When a client try to test bandwidth, always get small amount, and ping to a server usually time-out, buuuuut … when browsing not that slow because connection to the proxy is in LAN
  • When i disable the redirection to the proxy server, i see that queue tree isn’t very effective ( i want a single client got 64 kb, but ended up got small amount, because another client uses the bandwidth)
    I use queue tree like this → limit at 64k max limit 512k
  • The proxy isn’t deliver packages like what LAN usually do (a.k.a slow)
My question :
  • Is there any way to utilize the proxy so it isn’t use high bandwidth, so the client could use the rest, because if i set proxy get high bandwidth, a client couldn’t even ping to yahoo for example
  • What is the effecient and effective way to use external proxy, and queueing BW for client
  • Is my setup is quite right?
Thx for all the upcoming answers
Every bit of ur answer would please me :slight_smile: :blush: :blush: :blush: :blush:
hiks.. anybody…
help me plzzz :frowning:
Limit the customer traffic before it can reach the proxy?
Helo Sten…
I think i see that my problem is the connection to the proxy
My current config is like this:
  • Client connect to the gateway router and the router redirect all connection with port 80 to proxy server
  • I use pcq to limit the user equally
    Here is my mangle setup:
/ ip firewall mangle
add chain=prerouting src-address-list=!localIP action=mark-packet new-packet-mark=all-intl-mark passthrough=yes comment="" \
    disabled=yes
add chain=prerouting src-address-list=localIP action=mark-packet new-packet-mark=all-regIP-mark passthrough=yes comment="" \
    disabled=yes
add chain=postrouting dst-address=10.5.9.3 action=mark-connection new-connection-mark=all-proxy-conn passthrough=yes \
    comment="All Proxy Download" disabled=no
add chain=prerouting connection-mark=all-proxy-conn action=mark-packet new-packet-mark=all-proxy-mark passthrough=yes \
    comment="" disabled=no
add chain=postrouting src-address-list=Customer-IP dst-address-list=Customer-IP action=mark-connection \
    new-connection-mark=our-local-conn passthrough=yes comment="" disabled=no
add chain=prerouting connection-mark=our-local-conn action=mark-packet new-packet-mark=our-local passthrough=yes \
add chain=postrouting dst-address=10.5.10.218 src-address-list=!localIP action=mark-connection \
    new-connection-mark=caffe1-intl-con passthrough=yes comment="" disabled=no
add chain=postrouting dst-address=10.5.10.220 src-address-list=!localIP action=mark-connection \
    new-connection-mark=caffe2-intl-con passthrough=yes comment="" disabled=no
add chain=prerouting connection-mark=caffe1-intl-con action=mark-packet new-packet-mark=caffe1-intl passthrough=yes \
add chain=prerouting connection-mark=caffe2-intl-con action=mark-packet new-packet-mark=caffe2-intl passthrough=yes \
with customer-list
/ip firewall address-list
add list=Customer-IP address=10.5.10.218 comment="caffe1" disabled=no
add list=Customer-IP address=10.5.10.220 comment="caffe2" disabled=no
add list=Customer-IP address=10.5.9.1 comment="MainGateway" disabled=yes
add list=Customer-IP address=10.5.9.3 comment="Proxy" disabled=yes
and this is my queue setup :
/queue tree
add name="Total-512K-down" parent=LAN packet-mark="" limit-at=512k queue=pcq_down priority=8 max-limit=512k burst-limit=0 \
    burst-threshold=0 burst-time=0s disabled=no
add name="caffe1-down" parent=Total-512K-down packet-mark=caffe1-intl limit-at=0 queue=pcq_down priority=8 max-limit=0 \
    burst-limit=0 burst-threshold=0 burst-time=0s disabled=no
add name="caffe2-down" parent=Total-512K-down packet-mark=caffe2-intl limit-at=0 queue=pcq_down priority=8 max-limit=0 \
add name="OurLocal" parent=global-in packet-mark=our-local limit-at=0 queue=default priority=8 max-limit=0 burst-limit=0 \
add name="all-proxy" parent=LAN packet-mark=all-proxy-mark limit-at=0 queue=pcq_down priority=8 max-limit=0 burst-limit=0 \
But i can’t see the our-local-conn in connection list, instead i see caffe1-intl-conn not our local connection. So i assume the traffic to the proxy is not looseless :frowning:
maybe because there is slice between my mangles ..
help me please.. onegaii :blush:
Is there anybody who could give me a hand…
my network is desperate needing help for bandwidth :frowning:
but i couldnt optimize it
hikz.. hikz…
what should i dooooooo :open_mouth:
