Help me! pppoe + radius....2 ISP 2 Wan without balancing
Good Evening. Ask for your help to configure my rb1200 to get this result: I have two Adsl lines of 2 different ISP with different speeds. Currently i have created a link poppe for authentication of the customers and their navigation (lan on eth1) via the isp 1 connected to eth2. I have not yet connected the second modem to eth3-. Now, the range of IP customers pppoe tip to your ISP’s gateway 1.
I would like to see other customers to whom I’d give a range of different IP, aimed to your ISP’s gateway 2, connected to eth3-. In practice: the customers with IP ranges 172.16.2 .xx-172.16.2 .xxx should point to and navigate with the isp 1 with gateway 10.0.5.1 connected to eth2, while other customers with IP range 172.16.3 .xx-172.16.3 .xxx should point to and navigate with the isp 2 with gateway 10.0.6.1 . The routerboard that use is connected to a radius server. Thanks to all of you who know me.
