Problem1:
I’m using Netmetal 5 with Ubiquiti 19dbi Sector ,
Base tower height 30 mtr,
Client using SXT lite5 at 7-10 mtr heights
But they getting signal very low even within 1km link
Tx/Rx -79/-74 dBm , CCQ 31/59% , Signal Noise : 39 dB
Wireless Protocol 802.11 also tried nv2 but same result
Problem 2:
Sometime 802.11 AP not connected properly with CPE
It’s show connecting
You need to confirm that your radio is connected either to the horizontal or vertical connector on the back of the antenna. If it is horizontally polarised you will need to rotate your SXT into the horizontal polarisation position.
Possibly the tilt is wrong. The ubiquity sectors may have built in down tilt of 3 degrees. So you might want to check that. If the antenna tilt is too high or low the beam might be missing your clients.
