Help me restore RB750
hi all, i try to restore RB750G to default mode , but it can not. i use Netinstall program to do it.Pls help me do this. and show me step by step if you can.
thanks
To make RB750 boot to netinstall, during power-on hold “res” button until led starts to blink.
Rest of netinstall instructions are found in the manual:
http://wiki.mikrotik.com/wiki/Manual:Netinstall
hi, i try to do this but it still not work. all Ethernet port can not connect to my PC, so i can not see it on Net install program. anyone can help me Pls. it is agent ..thanks
If all your recovery attempts fail due to bad ports contact your reseller for an exchange.
The steps you were given are the steps to start the NetInstall process. The 700 series boards don’t have serial consoles so there isn’t anything else for you to try.
Hi all,I just fine my problem.it is fail hardware.after I repair it,it was nomal.thank all for support me.
