Help me set up an unstable VLAN!
Hello, I managed to construct an inter plan.
Well, there’s a problem.
problem
A. The Internet measurement site takes a normal download speed of 470M to 500M, but upload speed is only 0.3M to 1M.
My network diagram is “inter vlan image: inter vlan.” Please look at the image.
** Structure vlan **
MGMT-VLAN = 200.168.10.0/24 [ VLAN - IDS = 100 ]
SUPERMICRO-VLAN = 200.168.20.0/24 [ VLAN - IDS = 20 ]
IBM-VLAN = 200.168.30.0/24 [ VLAN - IDS = 30 ]
A. Router’s eth 1 is a WAN port that receives a DHCP address from the ISP company.
B. eth2 on the router and LAN1 on the switch are trunk ports.
C. ROUTER eth 3 - eth 13 = vlan 100 MGMT,
SWITCH LAN2-4 = vlan 100 MGMT,
LAN 5 - LAN 8, LAN13,LAN14 = VLAN 20 SUPERMICRO,
LAN 9 - LAN 12, LAN15, 16LAN, 17 = VLAN 30 IBM VLAN
ROUTER configure
# Naming #
# name the device being configured
[cskisa@Router] >/system identity set name=”Router”
# VLAN OverView #
# 100 = MGMT VLAN [ 200.168.10.0/24 ]
# 20 = SUPERMICRO VLAN [ 200.168.20.0/24 ]
# 30 = IBM VLAN [ 200.168.30.0/24 ]
# Bridge #
# Create one bridge, set VLAN mode off while we configure
[cskisa@Router] >/interface bridge add name=BR1 protocol-mode=none vlan-filtering=no
# Trunk Ports #
# ingress behavior
[cskisa@Router] >/interface bridge port
# Purple Trunk. Leave pvid set to default of 1
[cskisa@Router] >/interface bridge port add bridge=BR1 interface=eth2
[cskisa@Router] >/interface bridge port add bridge=BR1 interface=eth3
[cskisa@Router] >/interface bridge port add bridge=BR1 interface=eth4
[cskisa@Router] >/interface bridge port add bridge=BR1 interface=eth5
[cskisa@Router] >/interface bridge port add bridge=BR1 interface=eth6
[cskisa@Router] >/interface bridge port add bridge=BR1 interface=eth7
[cskisa@Router] >/interface bridge port add bridge=BR1 interface=eth8
[cskisa@Router] >/interface bridge port add bridge=BR1 interface=eth9
[cskisa@Router] >/interface bridge port add bridge=BR1 interface=eth10
[cskisa@Router] >/interface bridge port add bridge=BR1 interface=eth11
[cskisa@Router] >/interface bridge port add bridge=BR1 interface=eth12
[cskisa@Router] >/interface bridge port add bridge=BR1 interface=eth13
# egress behavior
[cskisa@Router] >/interface bridge vlan
# Purple Trunk. These need IP Service [ L3 ], so add Bridge as member
[cskisa@Router] >/interface bridge vlan add bridge=BR1 tagged=BR1,eth2 vlan-ids=20
[cskisa@Router] >/interface bridge vlan add bridge=BR1 tagged=BR1,eth2 vlan-ids=30
[cskisa@Router] >/interface bridge vlan add bridge=BR1 tagged=BR1,eth2,eth3,eth4,eth5,eth6,eth7,eth8,eth9,eth10,eth11,eth12,eth13 vlan-ids=100
# IP Addressing & Routing #
# LAN facing router’s IP address on the MGMT-VLAN
[cskisa@Router] >/interface vlan add interface=BR1 name=MGMT-VLAN vlan-id=100
[cskisa@Router] >/ip address add address=200.168.10.1/24 interface=MGMT-VLAN
# DNS server [ QUAD9 DNS ] ,set to cache for LAN
[cskisa@Router] >/ip dns set allow-remote-requests=yes servers=”9.9.9.9”
# ISP to eth interface DHCP setup
[cskisa@Router] >/ip dhcp-client add interface=eth1
# eth1 DHCP Client enable
[cskisa@Router] >/ip dhcp-client enable 0
# SUPERMICRO VLAN interface creation, IP assignment, and DHCP service
[cskisa@Router] >/interface vlan add interface=BR1 name=SUPERMICRO-VLAN vlan-id=20
[cskisa@Router] >/ip address add interface=SUPERMICRO-VLAN address=200.168.20.1/24
[cskisa@Router] >/ip pool add name=SUPERMICRO-POOL ranges=200.168.20.2-200.168.20.254
[cskisa@Router] >/ip dhcp-server add address-pool=SUPERMICRO-POOL interface=SUPERMICRO-VLAN name=SUPERMICRO-DHCP disabled=no
[cskisa@Router] >/ip dhcp-server network add address=200.168.20.0/24 dns-server=200.168.10.1 gateway=200.168.20.1
# IBM VLAN interface creation, IP assignment, and DHCP service
[cskisa@Router] >/interface vlan add interface=BR1 name=IBM-VLAN vlan-id=30
[cskisa@Router] >/ip address add interface=IBM-VLAN address=200.168.30.1/24
[cskisa@Router] >/ip pool add name=IBM-POOL ranges=200.168.30.2-200.168.30.254
[cskisa@Router] >/ip dhcp-server add address-pool=IBM-POOL interface=IBM-VLAN name=IBM-DHCP disabled=no
[cskisa@Router] >/ip dhcp-server network add address=200.168.30.0/24 dns-server=200.168.10.1 gateway=200.168.30.1
# Create a DHCP instance for MGMT-VLAN. Convenience feature for an admin.
[cskisa@Router] >/ip pool add name=MGMT-POOL ranges=200.168.10.10-200.168.10.254
[cskisa@Router] >/ip dhcp-server add address-pool=MGMT-POOL interface=MGMT-VLAN name=MGMT-DHCP disabled=no
[cskisa@Router] >/ip dhcp-server network add address=200.168.10.0/24 dns-server=200.168.10.1 gateway=200.168.10.1
# Firewalling & NAT rule                                                    #
# A good firewall for WAN, Up to you about how you want LAN to behave. #
# Use Mikrotik’s “list” feature for easy rule matchmaking.
[cskisa@Router] >/interface list add name=WAN
[cskisa@Router] >/interface list add name=VLAN
[cskisa@Router] >/interface list add name=MGMT
[cskisa@Router] >/interface list member add interface=eth1 list=WAN
[cskisa@Router] >/interface list member add interface=MGMT-VLAN list=VLAN
[cskisa@Router] >/interface list member add interface=SUPERMICRO-VLAN list=VLAN
[cskisa@Router] >/interface list member add interface=IBM-VLAN list=VLAN
[cskisa@Router] >/interface list member add interface=MGMT-VLAN list=MGMT
# INPUT CHAIN #
# VLAN aware firewall. Order is important.
[cskisa@Router] >/ip firewall filter
[cskisa@Router] >/ip firewall filter add chain=input action=accept connection-state=established,related comment=”Allow Estab & Related”
# Allow VLANs to access router services like DNS, Winbox, Naturally, you SHOULD make it more granular.
[cskisa@Router] >/ip firewall filter add chain=input action=accept in-interface-list=VLAN comment=”Allow VLAN”
# Allow MGMT-VLAN full access to the device for Winbox, etc.
[cskisa@Router] >/ip firewall filter add chain=input action=accept in-interface-list=MGMT comment=”Allow MGMT-VLAN Full Access”
[cskisa@Router] >/ip firewall filter add chain=input action=drop comment=”Drop”
# Add rules for VLANs to allow DNS services
[cskisa@Router] >/ip firewall filter add chain=input action=accept in-interface-list=VLAN dst-port=53 protocol=udp connection-state=new
[cskisa@Router] >/ip firewall filter add chain=input action=accept in-interface-list=VLAN dst-port=53 protocol=tcp connection-state=new
# FTP,SSH,Telnet Block access to a drop attacks.
[cskisa@Router] >/ip firewall filter add chain=input action=drop comment=”Drop FTP,SSH,Telnet from inbound” dst-port=21,22,23,137,139,445 protocol=tcp
# FORWARD CHAIN #
[cskisa@Router] >/ip firewall filter add chain=forward action=accept connection-state=established,related comment=”Allow Estab & Related”
# Allow all VLANs to access the Internet only, Not each other
[cskisa@Router] >/ip firewall filter add chain=forward action=accept connection-state=new in-interface-list=VLAN out-interface-list=WAN comment=”VLAN Internet Access only”
[cskisa@Router] >/ip firewall filter add chain=forward action=drop comment=”Drop”
# NAT #
[cskisa@Router] >/ip firewall nat add chain=srcnat action=masquerade out-interface-list=WAN comment=”Default masquerade”
# VLAN Security #
[cskisa@Router] >/interface bridge port set bridge=BR1 interface=eth2 ingress-filtering=yes frame-types=admit-only-vlan-tagged
[cskisa@Router] >/interface bridge port set bridge=BR1 interface=eth3 pvid=100 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged
[cskisa@Router] >/interface bridge port set bridge=BR1 interface=eth4 pvid=100 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged
[cskisa@Router] >/interface bridge port set bridge=BR1 interface=eth5 pvid=100 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged
[cskisa@Router] >/interface bridge port set bridge=BR1 interface=eth6 pvid=100 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged
[cskisa@Router] >/interface bridge port set bridge=BR1 interface=eth7 pvid=100 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged
[cskisa@Router] >/interface bridge port set bridge=BR1 interface=eth8 pvid=100 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged
[cskisa@Router] >/interface bridge port set bridge=BR1 interface=eth9 pvid=100 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged
[cskisa@Router] >/interface bridge port set bridge=BR1 interface=eth10 pvid=100 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged
[cskisa@Router] >/interface bridge port set bridge=BR1 interface=eth11 pvid=100 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged
[cskisa@Router] >/interface bridge port set bridge=BR1 interface=eth12 pvid=100 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged
[cskisa@Router] >/interface bridge port set bridge=BR1 interface=eth13 pvid=100 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged
# MAC Server Settings #
# Ensure only visibility and availability from MGMT-VLAN, the MGMT network
[cskisa@Router] >/ip neighbor discovery-settings set discover-interface-list=MGMT
[cskisa@Router] >/tool mac-server mac-winbox set allowed-interface-list=MGMT
[cskisa@Router] >/tool mac-server set allowed-interface-list=MGMT
# Turn on VLAN mode #
[cskisa@Router] >/interface bridge set BR1 vlan-filtering=yes
Switch configure
# Naming #
[cskisa@Switch] >/system identity set name=”Switch”
# INPUT CHAIN #
# firewall. Order is important.
[cskisa@Switch] >/ip firewall filter
[cskisa@Switch] >/ip firewall filter add chain=input action=input comment=”Drop,SSH,Telnet from inbound” dst-port=21,22,23,137,139,445 protocol=tcp
# DNS Setting #
[cskisa@Switch] >/ip dns set allow-remote-requests=yes servers=”9.9.9.9”
# VLAN OverView #
# Bridge #
# create one bridge, set VLAN mode off while we configure
[cskisa@Switch] >/interface bridge add name=BR1 protocol-mode=none vlan-filtering=no
# ACCESS Port #
# ingress behavior
[cskisa@Switch] >/interface bridge port
# MGMT VLAN
[cskisa@Switch] >/interface bridge port add bridge=BR1 interface=LAN2 pvid=100
[cskisa@Switch] >/interface bridge port add bridge=BR1 interface=LAN3 pvid=100
[cskisa@Switch] >/interface bridge port add bridge=BR1 interface=LAN4 pvid=100
# SUPERMICRO VLAN
[cskisa@Switch] >/interface bridge port add bridge=BR1 interface=LAN5 pvid=20
[cskisa@Switch] >/interface bridge port add bridge=BR1 interface=LAN6 pvid=20
[cskisa@Switch] >/interface bridge port add bridge=BR1 interface=LAN7 pvid=20
[cskisa@Switch] >/interface bridge port add bridge=BR1 interface=LAN8 pvid=20
[cskisa@Switch] >/interface bridge port add bridge=BR1 interface=LAN13 pvid=20
[cskisa@Switch] >/interface bridge port add bridge=BR1 interface=LAN14 pvid=20
# IBM VLAN
[cskisa@Switch] >/interface bridge port add bridge=BR1 interface=LAN9 pvid=30
[cskisa@Switch] >/interface bridge port add bridge=BR1 interface=LAN10 pvid=30
[cskisa@Switch] >/interface bridge port add bridge=BR1 interface=LAN11 pvid=30
[cskisa@Switch] >/interface bridge port add bridge=BR1 interface=LAN12 pvid=30
[cskisa@Switch] >/interface bridge port add bridge=BR1 interface=LAN15 pvid=30
[cskisa@Switch] >/interface bridge port add bridge=BR1 interface=LAN16 pvid=30
[cskisa@Switch] >/interface bridge port add bridge=BR1 interface=LAN17 pvid=30
# engress behavior
[cskisa@Switch] >/interface bridge vlan
# IBM, SUPERMICRO VLAN
[cskisa@Switch] >/interface bridge vlan add bridge=BR1 untagged=LAN5,LAN6,LAN7,LAN8,LAN13,LAN14 vlan-ids=20
[cskisa@Switch] >/interface bridge vlan add bridge=BR1 untagged=LAN9,LAN10,LAN11,LAN12,LAN15,LAN16 vlan-ids=30
[cskisa@Switch] >/interface bridge vlan add bridge=BR1 untagged=LAN2,LAN3,LAN4 vlan-ids=100
# Trunk Ports #
# egress behavior
# engress behavior
# Purple Trunk. L2 switching only, Bridge not needed as tagged member [ except MGMT-VLAN ]
[cskisa@Switch] >/interface bridge vlan set bridge=BR1 tagged=BR1,LAN1 untagged=LAN5,LAN6,LAN7,LAN8,LAN13,LAN14 vlan-ids=20
[cskisa@Switch] >/interface bridge vlan set bridge=BR1 tagged=BR1,LAN1 untagged=LAN9,LAN10,LAN11,LAN12,LAN15,LAN16,LAN17 vlan-ids=30
[cskisa@Switch] >/interface bridge vlan set bridge=BR1 tagged=BR1,LAN1 untagged=LAN2,LAN3,LAN4 vlan-ids=100
# LAN facing Switch’s IP address on a MGMT-LAN
[cskisa@Switch] >/interface vlan qdd interface=BR1 name=MGMT-VLAN vlan-id=100
[cskisa@Switch] >/ip address add address=200.168.10.2/24 interface=MGMT-VLAN
# The Router’s IP this switch will use
[cskisa@Switch] >/ip route add distance=1 gateway=200.168.10.1
# VLAN Security #
# Only allow ingress packets without tags on ACCESS ports
[cskisa@Switch] >/interface bridge port set bridge=BR1 interface=LAN2 pvid=100 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged
[cskisa@Switch] >/interface bridge port set bridge=BR1 interface=LAN3 pvid=100 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged
[cskisa@Switch] >/interface bridge port set bridge=BR1 interface=LAN4 pvid=100 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged
[cskisa@Switch] >/interface bridge port set bridge=BR1 interface=LAN5 pvid=20 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged
[cskisa@Switch] >/interface bridge port set bridge=BR1 interface=LAN6 pvid=20 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged
[cskisa@Switch] >/interface bridge port set bridge=BR1 interface=LAN7 pvid=20 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged
[cskisa@Switch] >/interface bridge port set bridge=BR1 interface=LAN8 pvid=20 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged
[cskisa@Switch] >/interface bridge port set bridge=BR1 interface=LAN13 pvid=20 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged
[cskisa@Switch] >/interface bridge port set bridge=BR1 interface=LAN14 pvid=20 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged
[cskisa@Switch] >/interface bridge port set bridge=BR1 interface=LAN9 pvid=30 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged
[cskisa@Switch] >/interface bridge port set bridge=BR1 interface=LAN10 pvid=30 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged
[cskisa@Switch] >/interface bridge port set bridge=BR1 interface=LAN11 pvid=30 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged
[cskisa@Switch] >/interface bridge port set bridge=BR1 interface=LAN12 pvid=30 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged
[cskisa@Switch] >/interface bridge port set bridge=BR1 interface=LAN15 pvid=30 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged
[cskisa@Switch] >/interface bridge port set bridge=BR1 interface=LAN16 pvid=30 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged
[cskisa@Switch] >/interface bridge port set bridge=BR1 interface=LAN17 pvid=30 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged
# Only allow ingress packets With tags on Trunk Ports
[cskisa@Switch] >/interface bridge port set bridge=BR1 interface=LAN1 ingress-filtering=yes frame-types=admit-only-vlan-tagged
[cskisa@Switch] >/interface list add name=MGMT
[cskisa@Switch] >/interface list member add interface=MGMT-VLAN list=MGMT
[cskisa@Switch] >/ip neighbor discovery-settings set discover-interface-list=MGMT
[cskisa@Switch] >/tool mac-server mac-winbox set allowed-interface-list=MGMT
[cskisa@Switch] >/tool mac-server set allowed-interface-list=MGMT
[cskisa@Switch] >/interface bridge set BR1 vlan-filtering=yes
Symptoms of the current problem.
A. Ping is successful from Google dns [8.8.8.8 ] and Quad 9 DNS [9.9.9 ].
B. The Internet is also good.
C. But I can feel the Internet bumbling when I not set up the Quick Set.
I think this is a problem before “FAST TRACK” was established. I have not set up MTU yet
Help me get the upload speed.
RB1100AHx4v1.rsc (5.71 KB)
CRS317-1G-16S+v1.rsc (4.28 KB)
THe problem is this line in the RB…
vlan-ids=100
If you look back, I stated to put it like so…
add bridge=BR1 tagged=BR1,eth2 untagged=eth3,eth4,eth5,eth6,eth7,eth8,eth9,eth10,eth11,eth12 vlan-ids=100
Eth3-12 are access ports and thus required to be untagged at the vlan interface settings.
Remember. Bridge ports are where one defines ingress rules (and thus the pvid=100 etc…)
interface vlan rules are where one defines egress rules (and thus we untag the packets when they leave for access ports).
Hello, anav!
I succeeded in communicating with ipmi on the server.
[ I learned later that ipmi communication was not originally available! ]
It was applied as anav proposal:
But it’s still in communication with the server, but the upload speed is still not normal.
image file : slow upload
image file : RB1100AHx4 interface photo
image file : CRS317-1G-16S+ interface photo
I’m still confused…
I’m sure they’re communicating, but the upload’s slow.
I don’t use a torrent for the last time.
Hello, anav
I reconfigured the device and changed the client device.
And I found out that there was a fatal flaw in the client device.
The client device was using the “Killer Lan” and the “Killer Lan” device was known to cause a driver crash by Microsoft update.
The phenomenon that Killer Lan caused was slowing down the upload speed except for the download speed.
We’re retrying the mikrotik device today and we’re telling you that it’s been successful.
Finally, I thank you for your advice.
Good news then!
