i have a pppoe client which connects me to the internet and a pppoe server which i connect my clients to me.
ok now my pppoe client connects with 1480 mtu and mru and the server gives to my clients 1480 mtu and 1488 mru.
and the web browsing is too slow and also download , i tried the connection without the mikrotik its faster , so there is a problem and i think its with the mss 95%. can someone help me how i change them or anything to do . thank you.
Use the change-tcp-mss option.
[admin@111lucia] > /ppp profile print
Flags: * - default
0 * name="default" local-address=10.0.54.1 use-compression=default use-vj-compression=default use-encryption=default only-one=default change-tcp-mss=yes
[.code]
Also you can change all packets tcp-mss as required.
[…] ip firewall mangle> chain=forward protocol=tcp tcp-flags=syn action=change-mss new-mss=XXXX
Replace the XXXX with your desired mss.
Rafiq…
