Help me with this script
I have 2 simple scripts put on system scripts:
:global NUM 100
:global NUM ($NUM+1)
On the ROS v2.9.51, when I run script1 then open terminal:
:put $NUM
100
I run script2 and in the same terminal:
:put $NUM
101
The script is running well as I expect it.
But when I run those scripts on ROS v3.11, the strange happens:
:put $NUM
100
:put $NUM
1
That’s not I expect it.
On the ROS v3.11 when I declare global variable at the terminal:
:global STRG "This is a tes"
Then make a script3 on system scripts:
:log info $STRG
I run script3 then watch the system log, nothing happen there, it should be a line contains “This is a test”. Apparently script 3 can not see $STRG variable which is already defined global at the terminal.
Somebody help me please! I am considering downgrade ROS 3.11 to stable version 2.9.51 if the problem still can’t be solved.
Thanks in advance.
Script1
:global NUM 100;
Script2
:global NUM;
:set NUM ($NUM+1);
:put $NUM;
