There is such a script
:local exists false; :foreach i in=[/queue simple find name=user1 limit=1k/1k] do={:log info ("Blocked" ); :set exists true}; :if (!$exists) do={ :log info ("Active" ) }
Please help me write a similar script using the API
<?php function f_add_user($login, $speed) { require('routeros_api.class.php'); $API = new RouterosAPI(); if ($API->connect('10.0.0.11', 'user', '12345')) { $API->write('/queue/simple/print', false); $API->write('?name='. $login, '?limit='. $limit, false); $API->write('=.proplist=.id'); $ARRAYS = $API->read();
