I have a problem when merged two separate Internet happen to the messenger and web every five minutes but when worked on the line of the Internet and only one gets what is the solution of this problem…
speak english you do? do understand no one does? skills english important very, understand people do will then help perhaps ![]()
I cant follow…
My point exactly ![]()
ok , i have 2 isp lan 1m and 1m when i work Load Balancing for Merge tow lan the messenger and web drop each 5 min. this is the problem
