Help Mikrotik AC3
Hello Team,
I have an problem with my share screen from laptop to tv!!
My network is created in this way :
I have created a subnet 200.0/24 for Lan interfaces apart the ether 5 , all interfaces are inside a bridge
The ether 5 has the subnet 50.0/24 and is connected a Unifi ac lite for WIFI proposes.
In two subnets is created the DHCP server to provide the ip’s.
The problem is that my laptop that get the IP 50.x does not start share screen to my TV LG Smart Web OS that get the IP 200.x
when i try to find the name in discovery tab no name of my tv does not appear.(Laptop has Win 10 Pro OS installed)
I have created two rules in firewall to accept the forward from 50.0/24 to 200.0/24 and the opposite 200.0/24 to 50.0/24 but the problem is not resolved.
I Try to create a rule to permit the igmp on port 1900 it generates traffic but the problem is not resolved.
If you want a extra information just inform me.
Kindly waiting for any solution
Thank you
Follow instructions here and post your configuration:
http://forum.mikrotik.com/t/forum-rules/173010/1
