Hello everyone, I need your help. I am connecting two different ISP WAN connections to my MikroTik device, and my goal is to separate them based on LAN ports. For example, I want to use ISP1 when connected to port 1 and ISP2 when connected to port 2. I have prepared a configuration for this, but it’s not working stably. Yes, it does what I want, but the IP addresses seem to mix up. I have a web server (10.0.2.100), and when I use the configuration I set up, sometimes I can’t access it, and when I can, it’s very slow. When I disable the other WAN interface, the server works normally. I think there are some errors in the firewall settings. I would appreciate your help.
set [find default-name="ether1"] name=WAN-ISP1
set [find default-name="ether2"] name=WAN-ISP2
set [find default-name="ether3"] name=LAN-1
set [find default-name="ether4"] name=LAN-2
set [find default-name="ether5"] name=LAN-3
set [find default-name="ether6"] name=LAN-4
set [find default-name="ether7"] name=LAN-5
set [find default-name="ether8"] name=LAN-6
set [find default-name="ether9"] name=LAN-7
set [find default-name="ether10"] name=LAN-8
set [find default-name="ether11"] name=LAN-9
set [find default-name="ether12"] name=LAN-10
set [find default-name="ether13"] name=LAN-11
set [find default-name="ether14"] name=LAN-12
set [find default-name="ether15"] name=LAN-13
set [find default-name="ether16"] name=LAN-14
set [find default-name="ether17"] name=LAN-15
set [find default-name="ether18"] name=LAN-16
set [find default-name="ether19"] name=LAN-17
set [find default-name="ether20"] name=LAN-18
set [find default-name="ether21"] name=LAN-19
set [find default-name="ether22"] name=LAN-20
set [find default-name="ether23"] name=LAN-21
set [find default-name="ether24"] name=LAN-22
add name=LAN-ISP1
add name=LAN-ISP2
add bridge=LAN-ISP1 interface=LAN-1
add bridge=LAN-ISP1 interface=LAN-3
add bridge=LAN-ISP1 interface=LAN-5
add bridge=LAN-ISP1 interface=LAN-7
add bridge=LAN-ISP1 interface=LAN-9
add bridge=LAN-ISP1 interface=LAN-11
add bridge=LAN-ISP1 interface=LAN-13
add bridge=LAN-ISP1 interface=LAN-15
add bridge=LAN-ISP1 interface=LAN-17
add bridge=LAN-ISP1 interface=LAN-19
add bridge=LAN-ISP1 interface=LAN-21
add bridge=LAN-ISP2 interface=LAN-2
add bridge=LAN-ISP2 interface=LAN-4
add bridge=LAN-ISP2 interface=LAN-6
add bridge=LAN-ISP2 interface=LAN-8
add bridge=LAN-ISP2 interface=LAN-10
add bridge=LAN-ISP2 interface=LAN-12
add bridge=LAN-ISP2 interface=LAN-14
add bridge=LAN-ISP2 interface=LAN-16
add bridge=LAN-ISP2 interface=LAN-18
add bridge=LAN-ISP2 interface=LAN-20
add bridge=LAN-ISP2 interface=LAN-22
add address=10.0.2.1/24 interface=LAN-ISP1
add address=10.0.3.1/24 interface=LAN-ISP2
/ip dhcp-client
add interface=WAN-ISP1 disabled=no
add interface=WAN-ISP2 disabled=no
add chain=srcnat out-interface=WAN-ISP1 action=masquerade
add chain=srcnat out-interface=WAN-ISP2 action=masquerade
/ip firewall address-list
add list=LAN-ISP1 address=10.0.2.0/24
add list=LAN-ISP2 address=10.0.3.0/24
set servers=1.1.1.1,1.0.0.1
/routing table
add name=ISP1
add name=ISP2
/routing table
set ISP1 fib
set ISP2 fib
add gateway=WAN-ISP1 routing-table=ISP1 distance=1
add gateway=WAN-ISP2 routing-table=ISP2 distance=1
/ip firewall mangle
add chain=prerouting in-interface=LAN-1 action=mark-routing new-routing-mark=ISP1 passthrough=yes
add chain=prerouting in-interface=LAN-3 action=mark-routing new-routing-mark=ISP1 passthrough=yes
add chain=prerouting in-interface=LAN-5 action=mark-routing new-routing-mark=ISP1 passthrough=yes
add chain=prerouting in-interface=LAN-7 action=mark-routing new-routing-mark=ISP1 passthrough=yes
add chain=prerouting in-interface=LAN-9 action=mark-routing new-routing-mark=ISP1 passthrough=yes
add chain=prerouting in-interface=LAN-11 action=mark-routing new-routing-mark=ISP1 passthrough=yes
add chain=prerouting in-interface=LAN-13 action=mark-routing new-routing-mark=ISP1 passthrough=yes
add chain=prerouting in-interface=LAN-15 action=mark-routing new-routing-mark=ISP1 passthrough=yes
add chain=prerouting in-interface=LAN-17 action=mark-routing new-routing-mark=ISP1 passthrough=yes
add chain=prerouting in-interface=LAN-19 action=mark-routing new-routing-mark=ISP1 passthrough=yes
add chain=prerouting in-interface=LAN-21 action=mark-routing new-routing-mark=ISP1 passthrough=yes
add chain=prerouting in-interface=LAN-2 action=mark-routing new-routing-mark=ISP2 passthrough=yes
add chain=prerouting in-interface=LAN-4 action=mark-routing new-routing-mark=ISP2 passthrough=yes
add chain=prerouting in-interface=LAN-6 action=mark-routing new-routing-mark=ISP2 passthrough=yes
add chain=prerouting in-interface=LAN-8 action=mark-routing new-routing-mark=ISP2 passthrough=yes
add chain=prerouting in-interface=LAN-10 action=mark-routing new-routing-mark=ISP2 passthrough=yes
add chain=prerouting in-interface=LAN-12 action=mark-routing new-routing-mark=ISP2 passthrough=yes
add chain=prerouting in-interface=LAN-14 action=mark-routing new-routing-mark=ISP2 passthrough=yes
add chain=prerouting in-interface=LAN-16 action=mark-routing new-routing-mark=ISP2 passthrough=yes
add chain=prerouting in-interface=LAN-18 action=mark-routing new-routing-mark=ISP2 passthrough=yes
add chain=prerouting in-interface=LAN-20 action=mark-routing new-routing-mark=ISP2 passthrough=yes
add chain=prerouting in-interface=LAN-22 action=mark-routing new-routing-mark=ISP2 passthrough=yes
add name=IPPool-ISP1 ranges=10.0.2.2-10.0.2.254
add name=IPPool-ISP2 ranges=10.0.3.2-10.0.3.254
add address-pool=IPPool-ISP1 interface=LAN-ISP1 name=DHCPServer-ISP1
add address-pool=IPPool-ISP2 interface=LAN-ISP2 name=DHCPServer-ISP2
add address=10.0.2.0/24 gateway=10.0.2.1 dns-server=1.1.1.1
add address=10.0.3.0/24 gateway=10.0.3.1 dns-server=1.1.1.1
/ip dhcp-server enable DHCPServer-ISP1
/ip dhcp-server enable DHCPServer-ISP2
add chain=dstnat in-interface=WAN-ISP1 action=dst-nat to-addresses=10.0.2.100
/ip firewall
filter add chain=forward in-interface=WAN-ISP1 action=accept
