HELP!!!! Mikrotik on x86 don't boot
i install ros 5.11 on my new x86 router.
After installing finished and reboot system, i have a message on screen - loading system with initrd and blinkink cursor on next line
I waited 10 minutes but the system did’t boot.
after any restarts i have this problem too.
reinstalling did not solve the problem.
Please help! i should start system at this day.
system: core i3-2100, ECS h61h2-i2, corsair SSD 32gb, network - 1G int realtek and one ext 1G realtek pci-e
on other system Atom D525 this ros on this SSD boot well.
help!
Check disk UDMA mode. Set to lower and if it boots then go up until you find which mode works.
change mode to legacy,dont use CD-ROM to install,use netinstall
