Help Mikrotil pcc load balance max up and down limit PCC
Hello.
I am using a mikrotik cloud core as load balance with 3 ADSL lines through PPPoE with PCC
I will try and explain what I wish to do as much as I can.
Each ADSL line has 1MB up and 12MB down.
Is it possible to set a Limit on each ADSL Line (Each PPPoE connection)
For Example…
ADSL 1 (PPPoE 1) is at its maximum upload almost 1MB because it is at its maximum that next connection that is made will use DSL 2 or DSL 3 When DSL 2 Upload is at its maximum the next connection will use DSL 3
And when not at its maximum the Load Balance works as normal.
Thank you
