hi mrz any script to migrate hotspot users to userman users
you could write a script to parse hotspot users and run the command to import users into userman. It should be fairly trivial.
how?
it’s easy, for example get username and password and create user in usermanager
:foreach i in=[/ip hotspot user find] do={
:local user [/ip hotspot user get $i name];
:local pass [/ip hotspot user get $i password];
/tool user-manager user add name=$user password=$pass subscriber=admin
thanks and what about for mac address and ip
:local ip [/ip hotspot user get $i address];
/tool user-manager user add name=$user password=$pass ip-address=$ip subscriber=admin
user-manager doesn’t have a field for MAC addresses.
Hope that helps,
Felix
userman v4b4 contains caller ID (mac address)
Then add
:local mac [/ip hotspot user get $i mac-address];
and change the insert
/tool user-manager user add name=$user password=$pass ip-address=$ip whatever-property-holds-the-mac-address=$mac subscriber=admin
/tool user-manager user add name=$user password=$pass ip-address=$ip caller-id=$mac subscriber=admin
The caller-id field also works when tested on 3.25 - 3.28.
