Help ! My dst-nat doesn't work normally!
[admin@VTwall] ip firewall dst-nat> print
0 ;;; Webserver
in-interface=pppoe-out1 dst-address=:80 protocol=tcp action=nat
to-dst-address=192.168.0.6 to-dst-port=80
1 ;;; POP3
in-interface=pppoe-out1 dst-address=:110 protocol=tcp action=nat
to-dst-address=192.168.0.6 to-dst-port=110
2 ;;; IMAP
in-interface=pppoe-out1 dst-address=:143 protocol=tcp action=nat
to-dst-address=192.168.0.6 to-dst-port=143
3 ;;; HTTPS
in-interface=pppoe-out1 dst-address=:443 protocol=tcp action=nat
to-dst-address=192.168.0.6 to-dst-port=443
4 ;;; Terminal Service
in-interface=pppoe-out1 dst-address=:63390 protocol=tcp action=nat
to-dst-address=192.168.0.6 to-dst-port=63390
5 ;;; SMTP
in-interface=pppoe-out1 dst-address=:25 protocol=tcp action=nat
to-dst-address=192.168.0.6 to-dst-port=25
[admin@VTwall] ip firewall rule voatec> print
0 ;;; Allow established TCP connections
protocol=tcp connection-state=established action=accept
1 ;;; Allow UDP connections
protocol=udp action=accept
2 ;;; Allow ICMP messages
protocol=icmp action=accept
3 ;;; Allow smtp connections to server at 192.168.0.6
in-interface=pppoe-out1 dst-address=192.168.0.6/32:25 protocol=tcp tcp-options=syn-only
action=accept
4 ;;; Allow http connections to server at 192.168.0.6
in-interface=pppoe-out1 dst-address=192.168.0.6/32:80 protocol=tcp
tcp-options=syn-only action=accept
5 ;;; Allow POP connections to server at 192.168.0.6
in-interface=pppoe-out1 dst-address=192.168.0.6/32:110 protocol=tcp
6 ;;; Allow IMAP connections to server at 192.168.0.6
in-interface=pppoe-out1 dst-address=192.168.0.6/32:143 protocol=tcp
7 ;;; Allow SSL connections to server at 192.168.0.6
in-interface=pppoe-out1 dst-address=192.168.0.6/32:443 protocol=tcp
8 ;;; Allow Terminal Service connections to server at 192.168.0.6
in-interface=pppoe-out1 dst-address=192.168.0.6/32:63390 protocol=tcp
9 ;;; Reject and log everything else
action=reject log=yes
Look, the first 5 dst-nat rule can work fine, but the last one (SMTP) can’t work normally.
I try to telnet port number 25, it seems connected, but the connection will be drop in 2 seconds. All smtp connections from mail server outside would be disconnect.
Pls help me.
can somebody help me? :cry:
but mail from hotmail can be accepted
