Help! My first network test/try
Hi all!
This is my first time here and first time with Mikrotik devices, yesterday i bought 2 RB952Ui-5ac2nD-TC for test purposes.
I would try to configure a network like as follow:
eth1 as wan from main modem
eth2 in VLAN1
eth3, eth4 and eth5 in VLAN2
wlan1 (2Ghz) in VLAN3
wlan2 (5Ghz) in VLAN3
wlan3 (virtual ap) in VLAN2
wlan4 (virtual ap) in VLAN4
Each VLAN should have a DHCP server that provides a different IP class/range
I should be connected to wlan2/VLAN3 with my laptop and i would be able to see the devices connected to all the others VLAN but others VLAN should not be able search for me.
Each device in each VLAN must be able to see devices in same VLAN
I tried, for example, to create a bridge “bridge1”, set the port wlan2 on this bridge and create a DHCP server giving the pool to this bridge1 but when i connect a device to this network, the server does not provide an IP Address..
Can someone give me some input to figure out on this?
Regards,
Pietro.
