Any body help me on crs mikrotik switch that how do i limit bandwidth on vlan. i will explain the picture
Like i have a trunk port ether-2 there vlan-200 vlan-300 and vlan -400 . i do not want to limit bandwidth on port.
i want to limit bandwidth on vlan like i want to limit bandwidth for vlan-200. please any body suggest me the configuration.
google is your friend
I am no expert but a quick google found this which I think you could try:
http://forum.mikrotik.com/t/bandwidth-limiting-accross-vlan/25767/1
See how you go using V6 as this is an older post.
Thanks for your reply. But its in switch not in router. mikrotik qos policy for switch.But from CRS manual
i can not understand how limit bandwidth on vlan in CRS mikrotik switch.
I guess I misunderstood.
Sorry but I do not have much experience with the CRS yet myself.
Good luck.
You should post over in the Beginner Basics or General forums. The CRS runs RouterOS, not SwOS, so you’ll get much more visibility over in those forums.
Rate limiting is (usually) a router’s job. The CRS line of products have pretty weak CPUs for this type of task.
