Help, need to re-use my x86 license (same machine)
so i have an x86 system set up and the USB stick i was booting off of died on me. i tried installing the same ROS version to another USB drive of the same exact manufacturer, size, etc., but i was having nothing but problems getting it to boot off USB properly. so instead, i installed to a SATA hard drive, and it is working flawlessly, but now it has a different license #.
is there any way i can re-import my old license to this machine?
https://wiki.mikrotik.com/wiki/Manual:License#Can_I_Format_or_Re-Flash_the_drive.3F
https://wiki.mikrotik.com/wiki/Manual:Replacement_Key
:wink:
Like paolopoz says…
As far as I know the license is bound to the storage where ROS is installed on
and you can request a new key for a few $$ if your storage medium has died.
This is the only way I guess.
I could be wrong but I am sure that the MT support guys will help you out.
