help need VOIP QOS
Hi.
i have a callCenter and i am using sip accounts i want to put my voip traffic to QOS.
Plz tell me what are the Mangle rules and also Queues i can apply.
i am new in mikroitk so plz write the exit code for me
thanks
That’s a pretty tall order for a forum, but you might take a look at this :slight_smile:
http://forum.mikrotik.com/t/prioritize-voip-post-your-ideas/57468/1
i already read that topic but i did not fully understand it. As i tell that i am new in mikroitk so plz if possible u can write simple 1 or 2 mangle rules and Que so that i can add them
If you don’t understand the QOS topic then mangle rules by themselves aren’t going to help - QoS is pretty complicated. What is it that you don’t understand? What problem are you trying to solve?
