Physical ether1 will be the router’s management port. No problem with that.
Physical ether2 - video encoder with IP 10.2.100.2 (video encoder can do up to 4 streams but have only one physical interface), which should be streaming to:
Physical ether3: to IP 10.2.2.11 UDP 5000.
Physical ether4: to IP 10.2.2.90 UDP 2314.
Physical ether5: to IP 224.23.0.113 UDP 1234.
Interfaces 3, 4, and 5 should be isolated networks. So no communication between those.
With Torch, I can see the streams going on interface ether2, but any attempt to route the streams to desired physical interfaces resulted in no success.
Please, guide me in the correct direction. Thank you.
Everything in the range 10.2.0.0 till 10.2.255.254 , it is all one and the same subnet here, except the 224 (broadcast?) address.
AFAIK no routing will be done between interfaces of the same subnet, they are supposed to be bridged here.
The /16 probably is or has to be /24, and the ethernets not connected to a bridge.
Well, I did things I found on the forum like 1 LAN (Encoder) to 2 WAN (assuming the WAN are isolated ports), and everything ChatGPT suggested.
As I’m new to MikroTik, I tried different configs and reverted so many times, that now I can not tell exactly what I deed…
Now, again, I have a clean config.
No, I do not need a bridge. The interfaces should have designated IP addresses and isolation. The 224 one is a multicast stream. I need to redirect the specific stream from port 2 to the other physical ports.
Routing will not work if all interfaces are the same /16 subnet. What is the case in your config: /16 means that only 10.2 defines the network/subnet (netmask 255.255.0.0) , the rest is per host/device)
