help needed: how to connect hAP to Chateau
My home network runs on MikroTik Chateau LTE12. Laptops and mobiles are connected with it via WiFi, my workstation is connected via Ethernet. Internet comes from the internal LTE modem.
In the living room I have a MikroTik hAP into which a NAS, Raspberry Pi and a music player are connected (all via Ethernet). In order to control the music player I need to disconnect from the main WiFi network and connect to the hAP WiFi network. Currently Chateau and hAP are not connected to each other and as a result the hAP has no internet access.
What I need is to connect hAP via WiFi into Chateau WiFi network so it becomes a part of the main network. As a result I want the hAP and connected devices to have internet access and be able to control the music play while staying in the main WiFi network.
I’d be very grateful if someone could give me a detailed instruction how to do it :slight_smile:
I have unsuccessfully tried to follow this wiki: https://wiki.mikrotik.com/wiki/Transparently_Bridge_two_Networks but it didn’t work - the WDS interface was disabled and I have no idea how to activate it.
Thank you!
Looking for new update to the free system sound app.
Where is the public music mode and switches to playlists on the device?
You can specify a manual static lease for the HAP. with the IP address you want
